[mapguide-users] Is it possible to specify the schema version when connection to a WMS feature source?
von Wartburg, Jan BKSD
Jan.vonWartburg at bl.ch
Tue Dec 11 02:07:32 PST 2012
I tried to use this very same WMS feature source with 2.4, resulting in the error described in
http://osgeo-org.1560.n6.nabble.com/MGOS-2-4-amp-Maestro-4-0-4-Problem-with-WMS-connection-td5021424.html
So right now, I can't use this feature source with 2.4.
Regards,
Jan
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Tuesday, December 11, 2012 3:31 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Is it possible to specify the schema version when connection to a WMS feature source?
BTW: there was a lot of work done for WMS compatibility after 2.2 which is available in 2.4
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc95
On Mon, Dec 10, 2012 at 10:18 PM, von Wartburg, Jan BKSD <Jan.vonWartburg at bl.ch<mailto:Jan.vonWartburg at bl.ch>> wrote:
That's it!
I was adding '?VERSION=1.1.1' to the URL of the feature source and now it works.
Thank you very much, Jackie!
Jan
P.S. I would like to find out why the FDO WMS provider doesn't like the 1.3.0 schema of this server...but for now, this issue is solved by adding the version parameter.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org> [mailto:mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org>] On Behalf Of Jackie Ng
Sent: Monday, December 10, 2012 11:48 AM
To: mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
Actually, if the WMS server operates like how MapGuide serves WMS, you could probably pass in a VERSION parameter in the URL to indicate the WMS version you want to work with.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Is-it-possible-to-specify-the-schema-version-when-connection-to-a-WMS-feature-source-tp5021855p5021857.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20121211/39c7ac81/attachment.html>
