[mapguide-users] Print utility
Zac Spitzer zac.spitzer at gmail.com
Thu Feb 2 19:19:35 EST 2012
can you elaborate in detail with screen shots?
which version of MGOS are you comparing it against?
On Fri, Feb 3, 2012 at 10:24 AM, pcardinal <pierre.cardinal at sympatico.ca> wrote:
> The print utility of MGOS has never been as good as the one of Mapguide 6.5
> (like no scale utility in MGOS, ...). What would be the best "solution" to
> obtain a better print utily with MGOS? I am still using MG_6.5 and avoid to
> use MGOS because of the weak print utility.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Print-utility-tp4360325p4360325.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
