[mapguide-users] Re: Print utility
pcardinal
pierre.cardinal at sympatico.ca
Sat Feb 4 17:11:41 EST 2012
It is in french, but in "Taille de la carte" (Size of the map) of MapGuide
6.5 it is possible to set the print scale. If I want a map at the scale
1/5000, I will type 5000 in the field next to 1: (with "Spécifier
l'échelle", in the example 353 595) . There no such "scale utility" in the
last MGOS ("Quick plot" does not do the job either).
The question is how to print a map at a specific scale ? What is the
solution?
Regards
http://osgeo-org.1560.n6.nabble.com/file/n4365628/Capture.jpg
View this message in context: http://osgeo-org.1560.n6.nabble.com/Print-utility-tp4360325p4365628.html
