[mapguide-users] Re: Print utility
SteveS
steve.calpoly at gmail.com
Wed Feb 8 17:41:34 EST 2012
You can code it using the viewer and web extensions API's. Whether you're
rendering an image or a DWF, both methods take scale as an input parameters.
>From the viewer API use GetScale()
>From web extensions use the appropriate RenderingService or MappingService
function.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Print-utility-tp4360325p4377535.html
