[mapguide-users] Fixed scales with Base Layers?
torrini
maria.kallbach at geoplanteam.ch
Fri Feb 3 08:53:11 EST 2012
Hi list,
is that right that a map containing base layers has fixed scales? For
example: the following scales were tiled: 1'000, 2'000, 5'000 and 10'000.
The map then has only a zoom range from 1'000 to 10'000. Is there a way to
control the layer settings? It would be nice if the map can scale to 200 and
use from scale 1'000 on the direct DataConnection instead of the tiled
layers. Is that possible? What about Autodesk's AIMS?
Kind regards,
torrini
View this message in context: http://osgeo-org.1560.n6.nabble.com/Fixed-scales-with-Base-Layers-tp4361819p4361819.html
