[mapguide-users] Re: Maestro 4 ,
ODBC connection: Timeout while saving
Jackie Ng
jumpinjackie at gmail.com
Mon Feb 6 09:30:41 EST 2012
Ok, I suspect the validation (which happens on save) for some reason is doing
a full schema walk of the SQL Server database (all 350 tables!).
I'll have to check if such a full walk is necessary for what the validation
is trying to do.
As a workaround. Turn off validation on save (under Tools - Options)
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Maestro-4-ODBC-connection-Timeout-while-saving-tp4369169p4369510.html
