[mapguide-users] Re: Maestro 4 , ODBC connection: Timeout while
saving
von Wartburg, Jan BKSD
Jan.vonWartburg at bl.ch
Mon Feb 6 10:05:54 EST 2012
Thanks for the quick answer, Jackie.
Unfortunately, turning off the validation doesn't have an effect.
When I validate without saving I get the attached error message.
Jan
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Monday, February 06, 2012 3:31 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Re: Maestro 4 , ODBC connection: Timeout while saving
Ok, I suspect the validation (which happens on save) for some reason is doing a full schema walk of the SQL Server database (all 350 tables!).
I'll have to check if such a full walk is necessary for what the validation is trying to do.
As a workaround. Turn off validation on save (under Tools - Options)
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Maestro-4-ODBC-connection-Timeout-while-saving-tp4369169p4369510.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Validating resource: Session:b9696b8e-50d2-11e1-8000-001eec7532c4_en_7F0000010AFC0AFB0AFA//6f9ce142-f91a-448b-9ca1-17810b2981ee.FeatureSource
Error - OSGeo.MapGuide.ObjectModels.FeatureSource_1_0_0.FeatureSourceType: Failed in validator:
Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
