[mapguide-users] Re: Popup info on data with Google Maps as
external provider
martind
martin.dagan.work at gmail.com
Thu Feb 9 07:50:38 EST 2012
I'd like also to add that the OpenStreetMap layer doesn't work: the page
never finishes to load, it shows only the SHP layers, but the left menu is
empty and there is no OSM map. I in firebug, there is this error:
/OpenLayers.Layer.OSM[this.mapTag.layerOptions.type] is not a constructor/.
Does someone has the same problem?
I wonder if I can count on Fusion templates for a production usage.
Objectively, is it stable enough to be used for a public website?
View this message in context: http://osgeo-org.1560.n6.nabble.com/Popup-info-on-data-with-Google-Maps-as-external-provider-tp4376251p4379174.html
