[mapguide-users] Re: Darn DLL files again
Jackie Ng
jumpinjackie at gmail.com
Fri Feb 10 09:21:56 EST 2012
If you are using a custom-built LocalNative provider then the only reason I
can think of as to why "MapGuideDotNetApi.dll" is still be referenced is if
a previous application using this assembly had run and you haven't either
restarted the server/IIS or recycled the application pool where the
application runs under.
If you are referencing the 5 OSGeo assemblies then *nothing* should be
referencing MapGuideDotNetApi.dll
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Darn-DLL-files-again-tp4383375p4383431.html
