[mapguide-users] Re: Any success stories compiling MG OS 2.2 with Oracle provider on 64-bit Linux?
Riccardo Pucci riccardo.pucci at gruppoesc.it
Fri Feb 17 05:36:06 EST 2012
In my experience bug http://trac.osgeo.org/fdo/ticket/562 prevent
KingOracle fdo provider to work on linux (both 32 and 64 bit version).
I have no idea about using ogr provider compiled with oracle support.
Riccardo
Il 17/02/2012 03:36, Zac Spitzer ha scritto:
> that said, I know Trevor has been working on linux support
> I would recommend using trunk rather than the 2.2 branch in this case
> BTW you can always access a 64bit db using a 32bit app
> only the app and db client need to be the same architecture,
> the communication between FDO and Oracle is via TCP/IP
> On Fri, Feb 17, 2012 at 1:21 PM, Jackie Ng<jumpinjackie at gmail.com>  wrote:
>> Sad to say, the user story on Linux is still woefully bad as evidenced by the
>> volumes of identical questions on this mailing list as you've already
>> mentioned and most of the build instructions out there are either seriously
>> out of date or are not applicable to the Linux distro you are using. Just to
>> share my own personal experience, my last successful MapGuide linux build
>> was way back with MapGuide Open Source 1.2. That's 4 years ago!
>> MapGuide was recently pulled from the latest/next OSGeo LiveDVD for this
>> same reason. Nobody (myself included) could get the thing to build and/or
>> invest the time/resources to get the thing to build successfully.
>> No point trying to sugar-coat what is clearly still a major pain point.
>> - Jackie
>> View this message in context:http://osgeo-org.1560.n6.nabble.com/Any-success-stories-compiling-MG-OS-2-2-with-Oracle-provider-on-64-bit-Linux-tp4478273p4478431.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
