[mapguide-users] Re: Any success stories compiling MG OS 2.2 with
Oracle provider on 64-bit Linux?
Zac Spitzer
zac.spitzer at gmail.com
Thu Feb 16 21:36:34 EST 2012
that said, I know Trevor has been working on linux support
I would recommend using trunk rather than the 2.2 branch in this case
BTW you can always access a 64bit db using a 32bit app
only the app and db client need to be the same architecture,
the communication between FDO and Oracle is via TCP/IP
On Fri, Feb 17, 2012 at 1:21 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> Sad to say, the user story on Linux is still woefully bad as evidenced by the
> volumes of identical questions on this mailing list as you've already
> mentioned and most of the build instructions out there are either seriously
> out of date or are not applicable to the Linux distro you are using. Just to
> share my own personal experience, my last successful MapGuide linux build
> was way back with MapGuide Open Source 1.2. That's 4 years ago!
> MapGuide was recently pulled from the latest/next OSGeo LiveDVD for this
> same reason. Nobody (myself included) could get the thing to build and/or
> invest the time/resources to get the thing to build successfully.
> No point trying to sugar-coat what is clearly still a major pain point.
> - Jackie
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Any-success-stories-compiling-MG-OS-2-2-with-Oracle-provider-on-64-bit-Linux-tp4478273p4478431.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
