[mapguide-users] Re: FeatureSource has a different coordinate
system than the map
Lotte Doyle
doylelotte at gmail.com
Fri Feb 17 12:57:33 EST 2012
I'm working with shapefiles.
I started fresh and loaded one of the problematic maps. Layers consist of a shpfile of British Columbia (NAD83 Albers) and a shpfile of the Fraser River (NAD83 BC Environment Albers).
This is the access log for that session: http://pastie.org/pastes/3402765/text
It doesn't seem to indicate any problems and the Ajax Viewer seems to stop feeding updates once it freezes/CPU goes to 100%.
I think I should note here that MapGuide is patched.
Would MapGuide Server be more stable under Linux?
Thanks,
Lotte
On 2012-02-11 05:45, Jackie Ng wrote:
> What type of data are you working with here?
> Secondly, try observing the access log (not error log) as you are selecting
> the map. It could be spamming this log when it goes 100% CPU.
> - Jackie
