[mapguide-users] Re: FeatureSource has a different coordinate
system than the map
Zac Spitzer
zac.spitzer at gmail.com
Fri Feb 17 17:56:51 EST 2012
2.1 is an old release, 2.2 is much more stable
http://trac.osgeo.org/mapguide/wiki/Release/2.2/Notes#Installation
On Sat, Feb 18, 2012 at 4:57 AM, Lotte Doyle <doylelotte at gmail.com> wrote:
> I'm working with shapefiles.
> I started fresh and loaded one of the problematic maps. Layers consist of a shpfile of British Columbia (NAD83 Albers) and a shpfile of the Fraser River (NAD83 BC Environment Albers).
> This is the access log for that session: http://pastie.org/pastes/3402765/text
> It doesn't seem to indicate any problems and the Ajax Viewer seems to stop feeding updates once it freezes/CPU goes to 100%.
> I think I should note here that MapGuide is patched.
> Would MapGuide Server be more stable under Linux?
> Thanks,
> Lotte
> On 2012-02-11 05:45, Jackie Ng wrote:
>> What type of data are you working with here?
>> Secondly, try observing the access log (not error log) as you are selecting
>> the map. It could be spamming this log when it goes 100% CPU.
>> - Jackie
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
