[mapguide-users] RE: error on the map
Wendy.lim
wendy.lim at live.com
Mon Feb 20 19:56:10 EST 2012
Hi Jacky,
We're very new to this application. Appreciate if you elaborate how to
modify the ajaxmappane.templ and how to add a prefix to the message being
alert()'ed??
Thanks for your time
WL
[mailto:ml-node+s1560n4478437h24 at n6.nabble.com]
Sent: 17 February 2012 10:30
To: Wendy.lim
Subject: Re: error on the map
There are 3 instances of javascript alert() being called in
ajaxmappane.templ. Each instance is from an error callback function for a
failed AJAX request. So that dialog could be the result of:
1. A failed AJAX request
2. A failed rendering call
3. A failed selection rendering call
You could modify the ajaxmappane.templ and add a prefix to the message being
alert()'ed so you know what type of failure it actually is.
- Jackie
_____
If you reply to this email, your message will be added to the discussion
below:
http://osgeo-org.1560.n6.nabble.com/error-on-the-map-tp4471065p4478437.html
To unsubscribe from error on the map, click here
<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscr
ibe_by_code&node=4471065&code=d2VuZHkubGltQGxpdmUuY29tfDQ0NzEwNjV8LTE5MjE5OT
Q1NzI=> .
<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_vi
ewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.Basic
Namespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.
NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_e
mails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> NAML
View this message in context: http://osgeo-org.1560.n6.nabble.com/error-on-the-map-tp4471065p4489587.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120220/0264a6cc/attachment.html
