[mapguide-users] RE: error on the map
Wendy.lim wendy.lim at live.com
Fri Feb 17 07:06:28 EST 2012
Hi all,
We are using .net application to call AutoCAD map in our application. The
alert pops out when we create poly points and poly lines layers at 25
seconds. It pops out again after few seconds.
Any idea? Thanks
Wendy
[mailto:ml-node+s1560n4478437h24 at n6.nabble.com]
Sent: 17 February 2012 10:30
To: Wendy.lim
Subject: Re: error on the map
There are 3 instances of javascript alert() being called in
ajaxmappane.templ. Each instance is from an error callback function for a
failed AJAX request. So that dialog could be the result of:
 1. A failed AJAX request
 2. A failed rendering call
 3. A failed selection rendering call
You could modify the ajaxmappane.templ and add a prefix to the message being
alert()'ed so you know what type of failure it actually is.
- Jackie
  _____
If you reply to this email, your message will be added to the discussion
below:
http://osgeo-org.1560.n6.nabble.com/error-on-the-map-tp4471065p4478437.html
To unsubscribe from error on the map, click here
<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscr
ibe_by_code&node=4471065&code=d2VuZHkubGltQGxpdmUuY29tfDQ0NzEwNjV8LTE5MjE5OT
Q1NzI=> .
<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_vi
ewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.Basic
Namespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.
NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_e
mails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> NAML
View this message in context: http://osgeo-org.1560.n6.nabble.com/error-on-the-map-tp4471065p4479774.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120217/6ad89e21/attachment.html
