[mapguide-users] Re: error on the map
Jackie Ng jumpinjackie at gmail.com
Thu Feb 16 21:29:36 EST 2012
There are 3 instances of javascript alert() being called in
ajaxmappane.templ. Each instance is from an error callback function for a
failed AJAX request. So that dialog could be the result of:
 1. A failed AJAX request
 2. A failed rendering call
 3. A failed selection rendering call
You could modify the ajaxmappane.templ and add a prefix to the message being
alert()'ed so you know what type of failure it actually is.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/error-on-the-map-tp4471065p4478437.html
