[mapguide-users] SQLServer 2008 Spatial Views
sekko970 fabio.franceschini at techneteam.it
Tue Jan 3 05:28:13 EST 2012
I've the following problem:
I've created a SQL view with a simple join between two db tables.
Then I created a dataconnection using FDO SQLserver 2008 provider, and a
layer with the above view as datasource.
I see all the features on then map, but they aren't selectable; trying with
a view without joins, it works fine.
Are views supported in SQLServer Spatial Data Connection?
Is it an FDO bug?
I'm using FDO 3.5.
Thanks.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/SQLServer-2008-Spatial-Views-tp7146309p7146309.html
