[mapguide-users] SQLServer 2008 Spatial Views
Ivan Miličević
Ivan.Milicevic at supranet.hr
Tue Jan 3 06:39:38 EST 2012
It is possible.
Please take a look at: http://themapguyde.blogspot.com/2010/09/using-fdo-schema-overrides-redux.html
And http://themapguyde.blogspot.com/2010/08/using-fdo-schema-overrides.html
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of sekko970
Sent: Tuesday, January 03, 2012 11:28 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] SQLServer 2008 Spatial Views
I've the following problem:
I've created a SQL view with a simple join between two db tables.
Then I created a dataconnection using FDO SQLserver 2008 provider, and a layer with the above view as datasource.
I see all the features on then map, but they aren't selectable; trying with a view without joins, it works fine.
Are views supported in SQLServer Spatial Data Connection?
Is it an FDO bug?
I'm using FDO 3.5.
Thanks.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/SQLServer-2008-Spatial-Views-tp7146309p7146309.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
