[mapguide-users] Oracle 11gR2 - Basics..
Simon Pelicon simon at sl-king.com
Thu Jan 26 10:05:49 EST 2012
Hi!
Set your OracleSchema value to xxxx (you username or schema name where
table with geometry is stored)
OracleSchema    : " xxxx  "
Otherwise check  USER_SDO_GEOM_METADATA view.
King.Oracle provider will read ALL_SDO_GEOM_METADATA View and find tables
and columns with SDO_GEOMETRY data type.
For each pair Table-Column King.Oracle will create an FDO Feature class.
If you want a FDO Feature class to be created based on Oracle View than you
need to add a row in USER_SDO_GEOM_METADATA for that View.
Check and Update/Insert statement for USER_SDO_GEOM_METADATA for your
geometry
INSERT INTO USER_SDO_GEOM_METADATA
VALUES(
'EVENTS','GEOM',
    MDSYS.SDO_DIM_ARRAY(
    MDSYS.SDO_DIM_ELEMENT('X', -180, 180, 0.000000005),
    MDSYS.SDO_DIM_ELEMENT('Y', -90, 90, 0.000000005)
  4326   -- SRID
You must also create Spatial  index on that geometry.
Regards,
Simon
On Thu, Jan 26, 2012 at 3:54 PM, Birgir <bgu at geograf.dk> wrote:
> Hi,
> Ive just installed Oracle 11gR2 and I need to....
> create a new table
> import data to that table
> show the data in Mapguide.
> So far I've been able to install Oracle, create the table and importing the
> data to that table.
> Im also able to create a feature source (with KingOracle) to my Oracle
> database with the following connection parameters:
> Username                : xxxx
> Password                : xxxx
> Service                 : xe
> OracleSchema    : "empty"
> KindFdoClass    : "empty"
> SDE Schema      : "empty"
> But when I create a layer for my Oracle feature source, I recevie the
> following error message:
> "Feature Source (Library://.....) has no usable feature classes. Choose a
> different feature source."
> Does the error message mean that my database doesnt have a table with
> spatial context? if yes, what can I do to correct this?
> Regards,
> Birgir
> http://osgeo-org.1560.n6.nabble.com/Oracle-11gR2-Basics-tp4340841p4340841.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120126/2d0c3893/attachment.html
