[mapguide-users] RE: How to sort a selection set
Jackie Ng
jumpinjackie at gmail.com
Mon Jan 30 10:15:16 EST 2012
But what you are sort()'ing is an array of JSON objects right? That's why you
must pass a sorting function as a parameter to sort() because otherwise
sort() has no clue how the objects are to be sorted.
If it's an array of string literals, then sort() should do the alphabetic
sort
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/How-to-sort-a-selection-set-tp4344383p4350951.html
