RE: [mapguide-users] Re: WGS84.PseudoMercator Is Not Supported MGOS 2.2 64bit?
madair at dmsolutions.ca madair at dmsolutions.ca
Mon Jan 30 14:01:36 EST 2012
Just a guess but you also need to make sure you load the google API in your template?
Mike
-----Original Message-----
Sent: Monday, January 30, 2012 12:04pm
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Re: WGS84.PseudoMercator Is Not Supported MGOS 2.2 64bit?
Hi Gordon & Thank you for your Q reply.
>From the first moment I knew you are a neat & organized person :)
Not sure I understood the guidelines, "...had to tweak the
fusionSF-compress.js or Build it with ANT:",
keep in mind that I'm using .NET & IIS7
 I have performed the update on / generic.js but still the same error
message.
 Is there something I'm missing.
 In the picture attached - The Sheboygan sample application not working with
Google Maps, this time.
 Webpage error details
 "Message: 'google.maps.MapTypeId.ROADMAP' is null or not an object
 Line: 1
 Char: 1.03346 million
 Code: 0
 URI: http://www.geomind.co.il/mapguide/fusion/lib/fusionSF-compressed.js"
http://osgeo-org.1560.n6.nabble.com/file/n4351274/Untitled.png
View this message in context: http://osgeo-org.1560.n6.nabble.com/WGS84-PseudoMercator-Is-Not-Supported-MGOS-2-2-64bit-tp4184497p4351274.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120130/5fdb4f36/attachment.html
