[mapguide-users] Re: WGS84.PseudoMercator Is Not Supported MGOS 2.2 64bit?
GordonL gordon.luckett at arrowgeomatics.com
Mon Jan 30 17:24:24 EST 2012
Not really,
the item:
google.maps.MapTypeId  does not work for Google so I had to replace this
everywhere with either
G_PHYSICAL_MAP or G_NORMAL_MAP etc
If you are not familiar with ANT, then look at the FusionSF.js file, modify
it with the links above and use that one in your template (Aqua etc) rather
than the FusionSF-compressed.js
gordon
View this message in context: http://osgeo-org.1560.n6.nabble.com/WGS84-PseudoMercator-Is-Not-Supported-MGOS-2-2-64bit-tp4184497p4352077.html
