[mapguide-users] PostGIS connection crashes MapGuide server
Jackie Ng jumpinjackie at gmail.com
Tue Jul 10 03:18:40 PDT 2012
Which provider are you using?
OSGeo.PostGIS?
OSGeo.PostgreSQL?
If it's the first one (OSGeo.PostGIS), you are *strongly* advised to stop
using it. Not only is it buggy and unstable, it is also no longer included
with newer versions of MapGuide / FDO since that 2.2 release.
If it's the other one (OSGeo.PostgreSQL), you are using what is essentially
a v1.0 provider with plenty of un-tested corner cases that have since been
been patched up and improved with subsequent versions of FDO.
So 2.2 is bit of a mixed bag if PostGIS connectivity is what you're after.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/PostGIS-connection-crashes-MapGuide-server-tp4987163p4987202.html
