[mapguide-users] PostGIS connection crashes MapGuide server
von Wartburg, Jan BKSD Jan.vonWartburg at bl.ch
Tue Jul 10 03:29:49 PDT 2012
I'm using OSGeo.PostgreSQL.
So there may be no solution to my problem when using 2.2...
That's a pity, because moving to 2.4 is not makeable for me right now.
Jan
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Tuesday, July 10, 2012 12:19 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] PostGIS connection crashes MapGuide server
Which provider are you using?
OSGeo.PostGIS?
OSGeo.PostgreSQL?
If it's the first one (OSGeo.PostGIS), you are *strongly* advised to stop using it. Not only is it buggy and unstable, it is also no longer included with newer versions of MapGuide / FDO since that 2.2 release.
If it's the other one (OSGeo.PostgreSQL), you are using what is essentially a v1.0 provider with plenty of un-tested corner cases that have since been been patched up and improved with subsequent versions of FDO.
So 2.2 is bit of a mixed bag if PostGIS connectivity is what you're after.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/PostGIS-connection-crashes-MapGuide-server-tp4987163p4987202.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
