[mapguide-users] PostGIS connection crashes MapGuide server
    Zac Spitzer
    zac.spitzer at gmail.com
    Tue Jul 10 03:47:57 PDT 2012
why isn't 2.4 an option, couldn't you at least try it out?
On Tue, Jul 10, 2012 at 8:29 PM, von Wartburg, Jan BKSD
<Jan.vonWartburg at bl.ch> wrote:
> I'm using OSGeo.PostgreSQL.
> So there may be no solution to my problem when using 2.2...
> That's a pity, because moving to 2.4 is not makeable for me right now.
> Jan
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: Tuesday, July 10, 2012 12:19 PM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] PostGIS connection crashes MapGuide server
> Which provider are you using?
> OSGeo.PostGIS?
> OSGeo.PostgreSQL?
> If it's the first one (OSGeo.PostGIS), you are *strongly* advised to stop using it. Not only is it buggy and unstable, it is also no longer included with newer versions of MapGuide / FDO since that 2.2 release.
> If it's the other one (OSGeo.PostgreSQL), you are using what is essentially a v1.0 provider with plenty of un-tested corner cases that have since been been patched up and improved with subsequent versions of FDO.
> So 2.2 is bit of a mixed bag if PostGIS connectivity is what you're after.
> - Jackie
> View this message in context: http://osgeo-org.1560.n6.nabble.com/PostGIS-connection-crashes-MapGuide-server-tp4987163p4987202.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
