[mapguide-users] You should probably read this (if you use Maestro)
mapas ansv.gis at gmail.com
Tue Jul 10 08:39:14 PDT 2012
hi, looks like a big problem! since the first version came out mgopensource
use, I always seemed an excellent job and a good development for the
community. Maybe someone from Autodesk that can help? I as a user I can
contribute little to troubleshoot code, but if I can install and test it in
different environments and error checking. I hope you continue with this
because I think an excellent job. jackie thanks for working with is an
excellent MAESTRO tool that allowed the community to move forward with this
project.
thanks a lot
View this message in context: http://osgeo-org.1560.n6.nabble.com/You-should-probably-read-this-if-you-use-Maestro-tp4987345p4987355.html
