[mapguide-users] PostGIS connection crashes MapGuide server
von Wartburg, Jan BKSD Jan.vonWartburg at bl.ch
Tue Jul 10 23:17:10 PDT 2012
Thank you Gabriele, I wasn't aware of the OGR provider with PostgreSQL support. I will check that out.
Regards,
Jan
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Gabriele Monfardini
Sent: Tuesday, July 10, 2012 4:20 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] PostGIS connection crashes MapGuide server
I'm on Mapguide 2.2 + Postgresql 8.3/8.4 (postgis 1.3)
I'm using the OGR provider with a GDAL recompiled to support PostgreSQL.
I'm on Linux, but it should be viable also on Windows.
I've tried with success gdal 1.6.3 and gdal 1.7.2 (the original gdal shipped with MG 2.2 is 1.6.0).
I think that every gdal 1.6.x should work since the increased minor number means bugfixes.
I've ever wondered why Mapguide does not ship a gdal with postgresql support (since is the preferred way to connect to PostGIS for a huge number of healthy free GIS software), since there are no licensing issues, it works white well and the OSGeo.PostgreSQL provider is yet not mature enough.
The reason is probably that if you have to enable it by yourself you cannot claim for support.
So, if you want to try, you should recompile gdal with postgresql support (it's very easy on most linuxes) or find a precompiled gdal 1.6.x (probably the easiest way on windows, try starting from http://trac.osgeo.org/gdal/wiki/DownloadingGdalBinaries).
Regards,
Gabriele Monfardini
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
