[mapguide-users] Error on insert features into SQL Server Spatial
Jackie Ng jumpinjackie at gmail.com
Wed Jul 11 04:25:45 PDT 2012
Are you using 2.4 RC1?
You've encountered a classic bug with UpdateFeatures that has been fixed for
this release:
http://trac.osgeo.org/mapguide/ticket/649
"Fixed" in the sense that such errors are now properly logged in Error.log
and that the API documentation has been updated to indicate if
MgPropertyCollection contains MgStringProperty instances, it means an
exception was thrown for the matching command in the
MgFeatureCommandCollection that was passed to UpdateFeatures.
You should probably check if the Identity Property for that Feature Class is
actually auto-generated to make sure nothing has been lost in DB -> FDO
schema translation.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Error-on-insert-features-into-SQL-Server-Spatial-tp4987600p4987607.html
