[mapguide-users] MG 2.4 RC1: PostGIS objects not selectable
von Wartburg, Jan BKSD Jan.vonWartburg at bl.ch
Tue Jul 17 00:44:40 PDT 2012
Thank you, Zac, that must be it. They don't have a primary key.
It is a remote database and I have only read access, so I cannot set the primary key on the database side. Is there a way to tell MapGuide directly which is the primary key in a table?
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Tuesday, July 17, 2012 9:27 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MG 2.4 RC1: PostGIS objects not selectable
do your tables all have a primary key defined?
On Tue, Jul 17, 2012 at 5:14 PM, JanvW <jan.vonwartburg at bl.ch> wrote:
> Hello,
> With 2.4 RC1 I can successfully connect to a remote PostGIS-DB. The
> 2.4 server isn't crashing anymore, unlike the 2.2 server (related post:
> http://osgeo-org.1560.n6.nabble.com/PostGIS-connection-crashes-MapGuide-server-td4987163.html).
> But there is still a problem:
> I cannot select PostGIS features in the Basic and Fusion Viewer. They
> are visible and set as selectable in Maestro. Other sources are
> selectable without problems.
> In the server error.log there is no error. The normal entries in the
> access.log when selecting objects (GetResourceContent, SelectFeatures
> etc.) are missing, so it seems that just nothing happens when I click
> on a PostGIS object. It's just about selecting: I can label the objects without problems.
> Has anyone made a similar experience and/or an idea?
> System:
> MGOS 2.4 RC1 (Apache)
> PostgreSQL 8.3
> PostGIS 1.3.6
> Maestro 4.0.1
> WinXP Pro 32bit
> Thanks,
> Jan
> http://osgeo-org.1560.n6.nabble.com/MG-2-4-RC1-PostGIS-objects-not-sel
> ectable-tp4988731.html Sent from the MapGuide Users mailing list
> archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
