[mapguide-users] MG 2.4 RC1: PostGIS objects not selectable
Zac Spitzer
zac.spitzer at gmail.com
Tue Jul 17 00:27:06 PDT 2012
do your tables all have a primary key defined?
On Tue, Jul 17, 2012 at 5:14 PM, JanvW <jan.vonwartburg at bl.ch> wrote:
> Hello,
> With 2.4 RC1 I can successfully connect to a remote PostGIS-DB. The 2.4
> server isn't crashing anymore, unlike the 2.2 server (related post:
> http://osgeo-org.1560.n6.nabble.com/PostGIS-connection-crashes-MapGuide-server-td4987163.html).
> But there is still a problem:
> I cannot select PostGIS features in the Basic and Fusion Viewer. They are
> visible and set as selectable in Maestro. Other sources are selectable
> without problems.
> In the server error.log there is no error. The normal entries in the
> access.log when selecting objects (GetResourceContent, SelectFeatures etc.)
> are missing, so it seems that just nothing happens when I click on a PostGIS
> object. It's just about selecting: I can label the objects without problems.
> Has anyone made a similar experience and/or an idea?
> System:
> MGOS 2.4 RC1 (Apache)
> PostgreSQL 8.3
> PostGIS 1.3.6
> Maestro 4.0.1
> WinXP Pro 32bit
> Thanks,
> Jan
> View this message in context: http://osgeo-org.1560.n6.nabble.com/MG-2-4-RC1-PostGIS-objects-not-selectable-tp4988731.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
