[mapguide-users] Appending selections without SHIFT-Click
David Das Neves
neves at systemtechnik.net
Thu Jul 26 23:23:36 PDT 2012
Jep jackie, you were assuming right and i found it.
Thanks a lot.
Greetings.
-----Ursprüngliche Nachricht-----
Von: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Jackie Ng
Gesendet: Freitag, 27. Juli 2012 03:47
An: mapguide-users at lists.osgeo.org
Betreff: Re: [mapguide-users] Appending selections without SHIFT-Click
Assuming you're talking about the AJAX viewer, selection appending behavior is controlled by the "appending" variable in ajaxmappane.templ and this variable is set to true on mouse down if the shift key is pressed.
So if you want a non-shift key method of toggling appending, just set this variable to true before selecting and (optionally) set it back to false once the new selection has been updated
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Appending-selections-without-SHIFT-Click-tp4991017p4991215.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
