[mapguide-users] Spatial Views with SQLite
Gunter Becker
gunter.becker at csogis.de
Tue Jun 5 04:12:14 PDT 2012
I'm trying to display a spatial view from SQLite in MapGuide 2.2. As you can
guess without any success.
I've created the view insde the SQLite Manager AddOn for Firefox. When I
display the view in the GUI everything seems to look fine.
Steps I've done already:
1. Create a view like this:
CREATE VIEW points
AS
SELECT a.id,
a.nr ,
b.geometry,
b.drehwinkel * 57.296 AS angle
FROM a JOIN b
ON a.id = b.p_id
2. Insert View in Metadata-Table 'geometry_columns':
INSERT INTO geometry_columns (f_table_name, f_geometry_column,
geometry_type, coord_dimension, srid, geometry_format)
VALUES ('points', 'geometry', 1, 2, 28532, 'WKB');
When trying to connect to sqlite in Maestro or FDOToolbox then the view
seems to be recognised as a spatial class. FdoToolbox shows a spatial icon
in the 'Object Explorer' and the 'Map View'- Tab is visible when querying
the data. Instead of displaying it correctly on the map it shows the
geometry-column as a column in the 'Grid View' with value '<null>'
As you can see from Jackies
http://themapguyde.blogspot.de/2010/09/sqlite-is-there-anything-you-cant-do.html
post it must be possible to display a spatial view. But not for me.
Anyone else who got this to work? Do I have to add some more metadata into
sqlite to make my view visible to MapGuide (FDO)?
Thanks, Gunter
View this message in context: http://osgeo-org.1560.n6.nabble.com/Spatial-Views-with-SQLite-tp4979185.html
