[mapguide-users] Spatial Views with SQLite
    Jackie Ng
    jumpinjackie at gmail.com
    Tue Jun  5 09:02:15 PDT 2012
There's 2 extra metadata tables you may need to fill in
fdo_columns: To describe the FDO data properties
spatial_ref_sys: To describe the FDO spatial context for that the geometry
property's SRID is describing.
Finally there's also a UseFdoMetadata connection property for the SQLite
provider that tells the provider to use these tables or make an intelligent
guess if false or not specified. It's probably making a bad guess?
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Spatial-Views-with-SQLite-tp4979185p4979271.html
