[mapguide-users] Adding a dataProperty to a buffer does not work
Marcelo Bilezker
marcebil at gmail.com
Wed Jun 27 15:27:56 PDT 2012
MapGuide 2.2
When creating a buffer, I want to save the buffer distance, as a property,
in the geometry created.
In buffer.php (which is in de mapviewerphp directory) , I saw this simple
lines (line 126, buffer.php)
//Set ID property.
$prop = new MgDataPropertyDefinition("ID");
$prop->SetDataType(MgPropertyType::Int32);
$classDef->GetProperties()->Add($prop);
So, I thought that adding: (I leave on purpose the Int32 type even that I
need it to be of type double, just to add the same code exactly):
//Set BDIST property.
$prop = new MgDataPropertyDefinition("BDIST");
Using the buffer icon (see attached), on the left up corner, stop working
after I add this 3 lines.
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120627/2ccd278e/attachment.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120627/2ccd278e/attachment.gif>
