[mapguide-users] mg 2.4+ubuntu 12.04 error connect postgres/mysql
mapas ansv.gis at gmail.com
Thu Jun 28 07:45:08 PDT 2012
hi, im install fine ... connect shp sqlite etc, but RDBMS Providers not work
, uninstall and reinstall but dont work... :)
shome this
The remote server returned an error: (559) MgFdoException.:
An exception occurred in FDO component.
CLNT_8_UNABLE_TO_LOAD_LIBRARY
System.Exception: The remote server returned an error: (559)
MgFdoException.:
 ---> System.Net.WebException: The remote server returned an error: (559)
MgFdoException.
   at System.Net.HttpWebRequest.GetResponse()
   at OSGeo.MapGuide.MaestroAPI.HttpServerConnection.OpenRead(String req) in
d:\Workspace\maestro-trunk\OSGeo.MapGuide.MaestroAPI.Http\HttpServerConnection.cs:line
1256
   --- End of inner exception stack trace ---
1270
   at
OSGeo.MapGuide.MaestroAPI.HttpServerConnection.GetProviderCapabilities(String
provider) in
1695
   at Maestro.Base.Editor.FsEditorOptionPanel.Bind(IEditorService service)
in
d:\Workspace\maestro-trunk\Maestro.Base\Editor\FsEditorOptionPanel.cs:line
60
   at Maestro.Base.Editor.FeatureSourceEditor.Bind(IEditorService service)
in
d:\Workspace\maestro-trunk\Maestro.Base\Editor\FeatureSourceEditor.cs:line
63
   at Maestro.Base.Editor.EditorContentBase.set_EditorService(IEditorService
value) in
d:\Workspace\maestro-trunk\Maestro.Base\Editor\EditorContentBase.cs:line 81
   at Maestro.Base.Services.OpenResourceManager.Open(IResource res,
IServerConnection conn, Boolean useXmlEditor, ISiteExplorer siteExp) in
d:\Workspace\maestro-trunk\Maestro.Base\Services\OpenResourceManager.cs:line
164
   at Maestro.Base.Services.OpenResourceManager.Open(String resourceId,
232
Object reference not set to an instance of an object.
System.NullReferenceException: Object reference not set to an instance of an
object.
   at Maestro.Base.Commands.NewItemCommand.Run() in
d:\Workspace\maestro-trunk\Maestro.Base\Commands\NewItemCommand.cs:line 64
   at ICSharpCode.Core.WinForms.MenuCommand.OnClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
   at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e,
ToolStripItemEventType met)
   at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e,
   at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons
button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ToolStrip.WndProc(Message& m)
   at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg,
IntPtr wparam, IntPtr lparam)
thanks a lot oscar
View this message in context: http://osgeo-org.1560.n6.nabble.com/mg-2-4-ubuntu-12-04-error-connect-postgres-mysql-tp4984589.html
