[mapguide-users] Re: FeatureSource has a different coordinate
system than the map
Lotte Doyle
doylelotte at gmail.com
Fri Mar 2 18:49:13 EST 2012
Flipper,
I think you put an end to all my concerns. I was not using a Load
Procedure resource. I re-imported the data as load procedures and the
UI flow is now much more responsive. Thanks!
On Fri, Mar 2, 2012 at 11:24, Flipper <scotth at mpowerinnovations.com> wrote:
> Are you pointing at the SHP files live or doing a load procedure....Live is
> Slow!
> Also how dense are the vertexes on the River...I.E. Over digitized?
> If they are over digitized Zach is Correct to generalize at different scales
> (weed out vertexes when zoomed out)
> However I don't believe Mastro can generalize SHP.
> In Studio I would normally Convert SHP to SDF during the load procedure as
> well, but I also believe this is not yet enabled in Mastro.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/FeatureSource-has-a-different-coordinate-system-than-the-map-tp4459279p4540189.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
