[mapguide-users] controlling label placement in polygons
Martin Morrison
martin.morrison at edsi.com
Tue Mar 6 22:09:27 EST 2012
Yes. Think about it. Just simply theme different rules using size as the criteria.
Martin
From: mapguide-users-bounces at lists.osgeo.org [mapguide-users-bounces at lists.osgeo.org] on behalf of Mark Volz [volzmark at yahoo.com]
Sent: Tuesday, March 06, 2012 9:59 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] controlling label placement in polygons
Hello,
What controls are there for labeling polygons. Specifically, is there any way to prioritize labels, prevent overlaps, or make sure they fit inside a feature geometry? Is there any documentation for editing files using xml, and if so can we do more in xml than what the dropdown tools allow in Maestro?
If there is no way to make labels fit to a polygon, is there a way to set up a rule so that mapguide labels only for larger parcels at a 1:10000 scale and then all parcels at a 1:2500 scale?
Thanks
