[mapguide-users] controlling label placement in polygons
Zac Spitzer zac.spitzer at gmail.com
Tue Mar 6 22:19:01 EST 2012
have you seen this?
http://trac.osgeo.org/mapguide/wiki/AdvancedStylization
z
On Wed, Mar 7, 2012 at 2:09 PM, Martin Morrison
<martin.morrison at edsi.com> wrote:
> Yes.  Think about it.   Just simply theme different rules using size as the criteria.
> Martin
> ________________________________
> From: mapguide-users-bounces at lists.osgeo.org [mapguide-users-bounces at lists.osgeo.org] on behalf of Mark Volz [volzmark at yahoo.com]
> Sent: Tuesday, March 06, 2012 9:59 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] controlling label placement in polygons
> Hello,
> What controls are there for labeling polygons.  Specifically, is there any way to prioritize labels, prevent overlaps, or make sure they fit inside a feature geometry?  Is there any documentation for editing files using xml, and if so can we do more in xml than what the dropdown tools allow in Maestro?
> If there is no way to make labels fit to a polygon, is there a way to set up a rule so that mapguide labels only for larger parcels at a 1:10000 scale and then all parcels at a 1:2500 scale?
> Thanks
> mapguide-users mailing list
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
