AW: [mapguide-users] Re: Setting the visibility of rules/classes of
layers
David Das Neves
neves at systemtechnik.net
Mon Mar 12 04:55:37 EDT 2012
Thanks for the reply.
Unfortunally was this also my first intention but this does not work because of our data structure.
I think that i have to get starting the semi-complicated way.
Greetings
David
-----Ursprüngliche Nachricht-----
Von: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Jamo
Gesendet: Freitag, 9. März 2012 04:24
An: mapguide-users at lists.osgeo.org
Betreff: [mapguide-users] Re: Setting the visibility of rules/classes of layers
I would suggest splitting each class into its own layer and nesting them all under a folder.
Otherwise you will have to write some code to adjust the layer filter and thats where things start to get semi-complicated.
Hope that helps :)
View this message in context: http://osgeo-org.1560.n6.nabble.com/Setting-the-visibility-of-rules-classes-of-layers-tp4557542p4560810.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
