[mapguide-users] Re: Scaling of mapguide opensource 2.2
Zac Spitzer zac.spitzer at gmail.com
Wed May 9 00:11:50 EDT 2012
But how many cores does this server have?
if you are using PNG for raster imagery, your bandwidth requirements will
be crazy, JPG will speed up your map delivery (from server to client)
and drastically reduce your bandwidth usage
Also, are you using tiled maps? that is really the only way
to scale things up for many users, especially with raster imagery
As I mentioned before, any FDO GDAL raster is single threaded which
is the real bottleneck. so if you need better performance, I really suggest
considering contributing some funds towards the following initiative
http://www.otxsystems.com/community-initiatives/gdal-provider-initiative.html
This multi-threaded GDAL provider will also prevent a crash within the provider
blocking all further GDAL requests, which is rather nasty in production
Regards
z
On Wed, May 9, 2012 at 2:00 PM, allfriends1990 <allfriends1990 at gmail.com> wrote:
> if the concept of support server is not there in mapguide opensource 2.2 then
> the hardware requirement will be huge as a  single server....i am using a
> server intel x series processor and about 7 GB RAM with about 2Mbps of
> server bandwith on my test server but still it supports hardly 3 users when
> surfing the hybrid view or satellite view , what would be the requirement
> if i need to scale it to 40 users is there any way so we can minimize the
> server hardware and bandwidth requirement and balance the load on mapguide
> server
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Scaling-of-mapguide-opensource-2-2-tp4955515p4962127.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
