[mapguide-users] Re: Scaling of mapguide opensource 2.2
allfriends1990
allfriends1990 at gmail.com
Wed May 9 00:22:29 EDT 2012
The processor of server is having 2 cores and support hyper threading.
I tried tiling the map but i need some layers as normal legend panel layers
and some layers like satellite layers as base layers(tiled layers) when i
tried same the map display is inconsistent
some layers are visible and tiled layers are not visible.....even if they
are in range of visibility
i tried using JPG format instead of PNG format waves off the transparency
and degrades the image quality
View this message in context: http://osgeo-org.1560.n6.nabble.com/Scaling-of-mapguide-opensource-2-2-tp4955515p4962149.html
