[mapguide-users] MgCooker - too much useless tiles generated
Franz1965
fsozzi at INTERCAD.CH
Wed May 9 17:13:17 EDT 2012
http://osgeo-org.1560.n6.nabble.com/file/n4964079/test.zip test.zip
Hi List,
I've made more tests on my MGOS 2.4 on both Windows 7 32bits and Windows
Server 2008 64bits and I think that there is a bug on how bounds are
calculated.
I've prepared a very simple project with only shp files on a very small
town.
I've set my serverconfig.ini as follows:
RenderOnly = 0
TileCachePath =C:\Program
Files\OSGeo\MapGuide\Server\Repositories\TileCache\
TileColumnsPerFolder = 500
TileRowsPerFolder = 500
DefaultTileSizeX = 1000
DefaultTileSizeY = 1000
ImageFormat = PNG
The wrong thing is that 90% of tiles created are black and this is of course
a great waste of time.
If you load my mgp and run the bat file with scaleindex=5 (I've included
CreateTiles.bat for that) you will see that only few tiles really regards
the map, the rest of tiles are black. With sclaeindex < 5 is even worse and
more you go toward scaleindex=0 and more useless black tiles you get.
To build all tiles scales on my Windows 7 I get an estimation of several
days (and taking a look to progress time against tiles generated, the
estimation looks correct).
Is it a bug or I'm wrong in doing something?...
View this message in context: http://osgeo-org.1560.n6.nabble.com/MgCooker-override-bounds-disabled-how-to-set-bounds-tp4963556p4964079.html
