[mapguide-users] Re: srsFactory.GetTransform
Jackie Ng
jumpinjackie at gmail.com
Mon May 14 10:33:25 EDT 2012
If you run both in interactive mode, they should both indicate the coordinate
system dictionary path, which should both be the value of
MentorDictionaryPath in serverconfig.ini.
2.4 does not use MENTOR_DICTIONARY_PATH environment variable by default.
However it will use this environment variable if the serverconfig.ini value
does not check out. And if this environment variable points to an older set
of dictionaries (from an older version of MapGuide), there could be trouble.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/srsFactory-GetTransform-tp4969498p4974459.html
