[mapguide-users] Fusion Background ignores map configuration
Wilson Herrera wherrera at pccadpanama.com
Mon May 28 14:10:42 PDT 2012
Good day,
i am deploying a map (no tiled, no external providers) in a fusion layout.
the map has a background color but this inst recognized by the fusion
layout, and shows a silver background.
nonetheless, overview map shows the correct background color.
attached, you can see the main map has no background color, the overview
shows the correct background color (the OM ratio is very big, thats why you
can only see the background in the overview not the actual carthography)
is there a way to fix this behavior?
Best regards,
wilson H.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Fusion-Background-ignores-map-configuration-tp4977548.html
