[mapguide-users] Import Package made by Infrastructure Map Server 2012
Hans Milling hm at geograf.dk
Tue May 29 04:39:10 PDT 2012
I solved this by copying the missing .XSD files from your C:\Program
Files\Autodesk\Autodesk Infrastructure Map Server 2012\Schema folder to the
C:\Program Files\OSGeo\MapGuide\Server\Schema folder (or where your MapGuide
installation is). Then use Maestro 4.01 (or 5b) to export/import the
package.
Best regards Hans Milling...
View this message in context: http://osgeo-org.1560.n6.nabble.com/Import-Package-made-by-Infrastructure-Map-Server-2012-tp4977700p4977714.html
