[mapguide-users] Import Package made by Infrastructure Map Server 2012
Zac Spitzer zac.spitzer at gmail.com
Tue May 29 04:16:10 PDT 2012
only with the test 2.4 releases
On Tue, May 29, 2012 at 9:11 PM, Reservoirdog <c.schmidt at relis.ch> wrote:
> Hello community!
> I have an electricity-project based on Autodesk Map 3D 2012.
> We have several "mapguide" servers running in our environment,
> however Map 3d 2012 can only publish to AIMS 2012.
> (Not possible to publish to older versions like MGOS 2.2, Topobase Client
> 2011 could.....)
> I thought about going indirectly on MG OS 2.2 via packaging.
> So i made a package of the published content on AIMS 2012 server and copied
> the package into the package repository of the MG OS 2.2. Then I tried to
> import this package, and got following error message:
> "An exception occurred in DB XML component. Error: The specified schema file
> is not found: C:\Program
> Files\OSGeo\MapGuide\Server\Schema\MapDefinition-2.3.0.xsd File:
> c:\builds\mg22x64\mgdev\server\src\services\resource\XmlSchemaResolver.cpp
> Line: 118"
> It seems, that the newer "mapdefiniton 2.3.0" coming from the newer server
> is missing in the mapguide os server. Is there any way to transfer the 63!!!
> layers from newest AIMS to MGOS?
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Import-Package-made-by-Infrastructure-Map-Server-2012-tp4977700.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
