[mapguide-users] Failed to load the resource file "Resources/mapguide_en.res" for locale "en".
Wilson Herrera wherrera at pccadpanama.com
Wed May 30 09:29:19 PDT 2012
checking in the error logs i found this:
The specified object was not found. - GetItem() line 114 file
d:\build\ims2013\build_52.8\ent\os\common\foundation\Data/NamedCollection.cpp
exception 'mguserinformation' in C:\Program Files\Autodesk\Autodesk
Infrastructure Web Server Extension 2013\www\xxxx\report.php:46 Stack trace:
#0 {main}
 exception 'mgsiteconnection' in C:\Program Files\Autodesk\Autodesk
Infrastructure Web Server Extension 2013\www\xxxx\report.php:47 Stack trace:
#0 {main}
View this message in context: http://osgeo-org.1560.n6.nabble.com/Failed-to-load-the-resource-file-Resources-mapguide-en-res-for-locale-en-tp4977857p4978091.html
