[mapguide-users] Failed to load the resource file "Resources/mapguide_en.res" for locale "en".
Wilson Herrera wherrera at pccadpanama.com
Tue May 29 13:48:16 PDT 2012
Good day everyone.
i am starting a project in php (mainly a report) but with the new version of
MGE this appears:
"en".
attached you can see a screenshot for the error, and the path to the .ini
this application is hosted on a 32 bit, windows server 2008, over IIS 7.
i found a similar thread before, using.net and i tought this could solve my
problem as well, so i tried to move the folders and after moving the
mapagent folder to another location, the error persists.
i checked that the webconfig.ini points to the location of the resource
file.
thank you for all your help,
Wilson
View this message in context: http://osgeo-org.1560.n6.nabble.com/Failed-to-load-the-resource-file-Resources-mapguide-en-res-for-locale-en-tp4977857.html
