[mapguide-users] SDFComponentToolkit.dll on 64Bit
Johnnie GIS johnniegis at gmail.com
Wed May 30 20:46:23 PDT 2012
Don't know whether it is an option or not but I ended up using FME from Safe to replace the Sdfcomponenttoolkit some time ago. Good luck.
Regards,
Jonathon McIntyre
i-Open Technologies
Twitter: @JohnnieGIS
www.i-opentech.com
(C) 778-549-8382
Sent from my iPhone, please excuse any typos.
On May 30, 2012, at 7:28 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> The way to workaround this would be to have a 32-bit front-end application
> (eg. A console application) for your class library using the SDF component
> toolkit.
> Then your 64-bit AutoCAD plugin becomes the controller for your 32-bit
> process. Your 32-bit front-end application would use return codes (or any
> other applicable interprocess communication mechanism) to communicate
> success/failure/etc back to the AutoCAD plugin.
> - Jackie
> View this message in context: http://osgeo-org.1560.n6.nabble.com/SDFComponentToolkit-dll-on-64Bit-tp4978012p4978179.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
