[mapguide-users] What is the best system specification for MG2.2 with 90ish layers?
JamesDudden jamesdudden at blueyonder.co.uk
Wed May 30 05:59:30 PDT 2012
I am about to set up a new installation of MG 2.2 using Microsoft Windows
Server Standard 2008 R2 + 5
 with the following resources:
Users: 5-15
Layers: 80ish (.shp, .tiff, Access database, SQL Express 2008)
Does anyone have any knowlegde of what would be a suitable system
specification?
Do the following specs seem ok and which is better suited to my needs?
Spec 1
Chassis                                   1U 4 Bay Hot Swappable
Processor                              2x E5-2609 Intel Quad-Core Xeon
2.4GHz 10Mb Cache
Memory                                2x 8GB 1333MHz DDR3 ECC Reg w/Parity
CL9 DIMM Dual Rank, x4 w/Therm Sen
Hard Drive                             3x 1TB Enterprise Class SAS2 6Gb/s
7200RPM - 3.5" - Seagate CONSTELLATION (RAID 5)
RAID Controller Card          LSI MegaRAID 9260-4i 6 Gb/s SAS/SATA RAID
Controller - LSI00201
Slim line Optical Bay            Slim line DVD-RW Dual Layer Drive
Operating System               Microsoft Windows Server Standard 2008 R2 + 5
CALS
Spec 2
Motherboard                       Xeon E3 X9SCL-F with Dual Gigabit LAN &
Dedicated LAN for IPMI & Remote KVM Management
Processor                              E3 1220 Intel Quad-Core Xeon 3.1GHz
8Mb Cache 5GT/s 80Watts
Memory                                2x 4GB 1333MHz DDR3 ECC CL9 DIMM with
Thermal Sensor
Hard Drive                             3x 1TB Enterprise Class SATA 7200RPM
- 3.5" - Seagate CONSTELLATION ES SATA 3Gb/s (RAID 5)
RAID Controller Card          Use On Board RAID of Motherboard
Slim line Optical Bay            Slim line DVD-RW Dual Layer Drive SATA
Accessories                           Front Bezel for SC813 & SC813M & SC815
& SC818 series
CALS
Any advice is appreciated
Regards
James
View this message in context: http://osgeo-org.1560.n6.nabble.com/What-is-the-best-system-specification-for-MG2-2-with-90ish-layers-tp4978036.html
